Hi
I just wanted to share with you the reading tracker I’ve built
For some context, I discovered Coda by chance, maybe 2 months ago, searching something completely different.
I didn’t test it right away because at that time, I had no idea of a database I could use as a test drive.
But then I began to read Spawn, a comics which I bought as “Collected”.
Usually, I use an app’ on my phone to track my readings, but, because there’s no page numbers in the comics, I couldn’t use it (well, I didn’t want to have to count each page I just read, I just wanted to enjoy the Comic
Plus, AFAIK, despite being an excellent app’, you still can’t re-read a book, which for me has always been kind of problem.
So, there was my missing idea
But before putting my brain into this, knowing nothing about Coda (what could be done and how), I checked the community and found this topic :
Which helped me to get started
Few weeks later (and a tremendous amount of knowledge more), mixing this simple base with the “automated” functionalities of the app’ I used before, I now have another " app’ " where I can track the readings of my books and comics and just enjoy them ! (In my personal doc, the tracker differentiates “Comics” from “Books” and I read the comics in number of issue(s) instead of pages
Plus, it allows re-readings too
So, I thought it might be useful to someone else ![]()
I tried to explain how it works in the doc as clearly as I could
(which is not easy and that’s why it’s a bit long
Don’t hesitate
: Try it, Test it, explore it, it’s there for that ![]()
Thanks for reading and helping me building this
PS: The other related topics that helped me are :
), after building this and actively see what it could do and where it could take me, I’m pretty sure I could “recreate” with Coda some other app’s I use that are great but always only satisfying me at 99%
with a good combination of structure and nice formulas and use of icons to get the doc visual attractive.
