I use both Coda
and Notion
, so my viewpoint is more of the comparison between them.
I tried calendar view, love it that it has day view
and week view; and is able to select duration column.
On the other side, the view lack some feature that Notion
has had:
- select and drag to expand the duration by days (it only work by hour in day view)
- select what column will present on time block, it only get titles presented. ( whileas column visibility is not being used here, that’s …)
(I wanna use calendar for time blocking.)
Thanks, Coda
is promising. (also for programmer, it has the flavor of programming integrate into the spreadsheet and doc and app.
