Can someone please share the parameters for the GoogleMap and/or GoogleDirections formulas? They are missing from the formulas list, but they seem to still work in a shared doc I copied.
Hi @anon98914249,
Very sorry for the, well, very late reply here.
Currently we include a Google Map or Directions through a link. If you start typing /embed anywhere in the canvas, it will prompt our slash command popup of options and should have embed options listed. There should be a Maps one where you can add a link. This is just the URL from the Google Maps site where you have the directions showing the way you want them to display in your Coda doc.
