Where the marketing program (say podcast) is refers to multiple activities all happening on different dates but viewable in a timeline. Is this possible?
hi @Luke_Bockelmann ,
welcome to the community
yes it is
you see options right top, go there and then select the time line view instead of the table view you have now. then play a bit with the settings
I am not using it often, but it works nicely, others like @joost_mineur can maybe give you better advice,
cheers, Christiaan
Welcome to the community!
There is a different kind of timeline also possible in Coda:
I know how to create a timeline the problem is that Marketing Activities (podcasts for example) show up in a list and are duplicate. I want Marketing programs on the left to be all of the same Marketing Activities (podcasts) and a time line of each podcast over time on the right in the timeline:
