"Other" for Lists in Forms
Does anyone know if it’s possible to add an “Other” section to a form dropdown/list? Example below:
See how there is an “Add Item” option on the backend, is it possible to allow those submitting a form to do the same?
Hi @anon49092417 :blush:
I may be wrong here but I don’t think it’s possible to do, at least in this simple way :confused:.
The only way I can think of to allow an “Other” (and re-use it in your doc) would be to create this option yourself and then have an “if other” text field in which the submitters can write her/his/their choice. Then in your table where the form sends the results, add a button to potentially add this new choice to your list of choice so you can re-use it later in your doc (depending on the purpose of your form).
The submitters though will not be allow to use that “new option” in the form :confused: but it will allow you to gather those “if other” options and work with them.
Hey Pch! Thanks - that’s what I thought. Trying to limit technical complexity because there are enough moving parts on the doc. Thank you regardless! :slightly_smiling_face:
