Hoping to get some some support and guidance surrounding the Typeform pack.
I have setup a Typeform table that receives responses from form submissions. In the Typeform, I have a question with multi-select options and the ability for a respondent to add a new response when selecting the “Other” option.
When testing using “Other”, it isn’t captured in the responses column.
I wonder if I am missing something or whether this option is not supported by the pack.
Hi @Anyi_Ndongko1 , thanks for reaching out and sorry you’re having some troubles with the pack. In order for us to determine what’s going on there, it sounds like we might need a little more information on how the “other” option is being filled in Typeform before we can confirm if it’s supported. Are you able to please open a conversation with our Support team by clicking the ? in the bottom right corner of your Coda screen and writing in?
