PDF Previews and Reading
A lot of explorations concerning PDF previewing and reading have been provided in the community. Here’s a little snippet showing how I approach this challenge and a document that shows it in action.
User Expectations
When we think of including PDF documents in a Coda app, the typical reaction is — … this user experience is not helpful.
What would be better?
Well, this is the requirements bar we set at Stream It:
  1. Must provide full in-line PDF document preview with scrolling.
  2. Must support expanded larger view with one click.
  3. Dynamic preview sizing in tables.
  4. Drag-and-drop additions; no custom or document-dependent formula edits.
The number-one requirement from users I’ve spoken with is the ability to scroll (or swipe) in the preview thumbnail because that’s how users find specific passages. Lacking the ability to perform a full text search, this is obviously the next best thing.
Coda checks all of these boxes if you know how to extract the URL of a Coda-bound file and embed it in a Canvas field. This document exposes these details.
Extracting the Coda URL for PDF Files
This is achieved with a formula in the hidden field PDF URL. It’s a little tricky but highly useful.
ParseJson(_Merge(thisRow.[PDF File]) + "", "#/publicUrl")
Embedding in a Canvas
With the URL for each file, it’s now possible to embed the document into a canvas field.
Embed(thisRow.[PDF URL])
In the example document, I’ve embedded the formula in each canvas item for demonstration purposes, but at Stream It, we tend to use canvas templates in cases like this. There’s a good discussion of templating canvasses here and here
That’s pretty neat work-around :slight_smile: Thanks for sharing it
This is amazing - thank you so much for sharing! SO useful!
thanks @Bill_French for sharing this
it is EXTREMELY useful
but not self evident
max
How did you hide the other columns from the canvas view?
Simple. Edit the layout of the Canvas field and remove all fields but Canvas itself.
Thank you! I appreciate it :slight_smile:
Hey @Bill_French, thanks so much for this tip. I’ve almost got it working but am encountering an error when uploading new files.
The PDF Formula doesn’t calculate until I change the formula (e.g., delete it and then replace it with the same formula). Then the PDF shows up as readable.
In the attached image, you can see the result I get when I upload a new article - just . The error in the “Reader” column is: “invalid embed URL”
Any ideas of where I’ve gone wrong?
Yeah - you haven’t done anything wrong. :wink:
As I mentioned in the article, this demo doc was prepared with the formulas for each record embedded in the canvas itself. I went on to say this is probably not the most ideal approach and you are seeing this first-hand.
I suspect there’s a way to remove the individual embeds and replace with a column formula, or follow those links to fabricate a more templated approach, one we use at Stream It but which I have no authority to share openly.
I’m struggling to see why the formula doesn’t work after upload, when it clearly does work, but only after re-loading the formula. I’m not familiar with the ParseJSON formula…
Yeah - all this does is extract the publicly-hosted address of the attached (uploaded) document.
I wonder if there’s a refresh issue that causing this to fail to produce the URL.
Solved this using the RefreshColumn() action.
User has to perform the extra step of clicking a refresh button after uploading the doc, but then the embed picks up the public URL and displays the PDF.
Thanks for your help @Bill_French
this only works with a pack row. How do you apply this to a normal formula row?
thanks
