Hey there again!
I have a chart plotting data contained in columns from a table.
If I add a new column to the table, this newly created column value does not appear on the dropdown list for the display options of the plot.
It annoys me everytime!
Any plans on tackling that?
Hello, thanks for contacting us.
Whatβs happening here is that new columns will be hidden in views.
You need to make visible the new columns in your desired view, like in the image below.
Regards!
Sorry about that @Higuel_Noroes , while we work through this, please follow @Jesus_Guzmanβs suggestions. Will update here once this is fixed.
Hello @Higuel_Noroes, team has solved this bug.
Regards!
