Hi Coda makers!
Right now you can (sort of) print your Coda docs but they don’t look great:
- File --> Print: for just one section
- Ctrl + P (or Cmnd + P on Macs): for the entire doc
While we work on making printing from Coda better for you, here’s a quick hack on how to use Zapier + Gmail pack to print a section in Coda:
Step 1: Create a zap using this template
Step 2: Install the Gmail pack in your Coda doc
Step 3: Add a button that sends a section as an email.
Step 4: In the button setup, type the name of the section you want to send in the “Content” field
Step 5: For the “To” address in the button setup, use the Zapier email that was autogenerated in the zap you created in Step 1.
Step 6: When you push the button, the section is sent to the Zapier email address, where it is then printed to a PDF using Google Cloud Print.
Step 7: If you want to send multiple sections as PDF, you can create a new button for each section, and then a master button that pushes all of the section buttons.
Note: it takes a minute or two after you push the button for the PDF to show up in your Google Drive.
Unfortunately, charts and other table views don’t come through very well using this hack. If you have charts, maybe take a screenshot and save that as a PDF. We know this isn’t ideal, but hopefully it helps until we can make printing in Coda even better
