Hi everyone, thank you for all for the feedback about the new typography. We are excited to make an update that will allow you to choose between line break sizes:
In a cell:
Enter → submit (unchanged)
Shift + Enter → hard line break (unchanged)
Option (Mac) or Alt (PC) + Enter → soft line break (new behavior)
On the canvas:
Shift + Enter → soft line break (new behavior)
Now, you can use these to create the desired spacing in your beautiful docs. Thank you again for the feedback and for being a Maker!
Thanks for that update! Line breaks are really important.
Out of interest I just tested if you can now create line breaks also for headings. The answer is - yes, but only with a little trick. Maybe this can be smoothed out in the future.
If you have just created a heading and the cursor is at the end of the heading, pressing Shift + Enter will not create a line break (thus a new line) for the heading.
However, if you place the cursor at the beginning of the heading and then press the Shift + Enter key shortcut, you will create a second line above the heading where you can insert text.
Now you have two lines for a heading, which you can edit as you like and even create more lines if you wish (now in the usual way).
Generally speaking: If you do not place the cursor at the end, but at any other place of the heading, then the line break with Shift + Enter works.
