PSA: How to make columns equally wide
A quick and non-obvious trick to make columns equally wide.
Just select multiple columns with shift pressed, then resize one of them, and all selected ones will get resized to the same width:
Woah, like woaahh!
This is a really big thing actually! Oh I’ve spent so many hours trying to make columns equal width, and I have over 80 columns in a table!
I’ve actually learned two things here - I didn’t know that you could select multiple columns with shift either!
A single page (like Coda’s formula directory) with all these tips would be suuuper helpful
A range of columns can be selected all at once by clicking the first and then the last while holding Shift. Selecting a range of items this way is actually a classic shortcut and most (all?) spreadsheets support it.
