The Coda guide for working with the command line (CLI) (as opposed to the web-based Pack Editor) proposes two approaches for installing the SDK (@codahq/packs-sdk node package). The first is to install it globally on your system. The only reason to install it globally is to access to the CLI tool that ships with the SDK when calling the coda
command, with no additional setup. Globally installing has a several drawbacks which I won’t go into here.
The guide itself recommends to install the SDK locally (I agree) in the “Single-Project Install” section:
It’s easier to manage dependencies and avoid version conflicts across projects if you create an npm project for your pack and install the SDK and other dependencies locally.
However, the approach suggested by the above guide for the single project install is not ideal IMO. Having to modify your system’s PATH just to use a CLI for one project is not really sustainable. If you have multiple Coda packs in development, your CLI will arbitrarily be the one shipped with the SDK installed for that one pack whose node_modules
was added to your PATH. That CLI might be a very different version from the SDK in other packs where you are running coda
commands, which can cause compatibility issues and make debugging difficult, as it’s easy to confuse the CLI’s actual version with the version of the SDK listed in your project’s package.json
. If you delete or move the project that was pointed to by your PATH, you will have to once more update your PATH to use the CLI. Both approaches also add another onboarding step when installing the project.
These are not problems unique to developing Coda packs, which is why tools like npx exist. With npx, you can simply install the Coda SDK locally (the same way as is indicated in the guide section linked above), but skip the part where you would modify your PATH variable. Instead, simply prefix your coda
commands with the npx
command/CLI. So for example,
coda upload path/to/pack.ts
would become
npx coda upload path/to/pack.ts
This is also the approach recommended by npm itself: Downloading and installing packages globally | npm Docs. npx comes comes bundled with npm version 5.2+, so there shouldn’t be any other installations required to follow this approach assuming you’ve installed/upgraded the latest npm within the last 4 years (just need to remember to prefix the coda ...
commands, otherwise you will get an error like “sh: command not found: coda” from your terminal). If your npm version is < 5.2, you can install npx globally (npm install -g npx
), but you should probably just upgrade your npm version
