I’ve looked for YEARS to find a convenient and simple way to create and import recipes, and I’m hoping to put one together in Coda to share recipes across our team (we’re big bakers).
Anyone have a similar sample document they’re willing to share, or ideas?
I’m thinking a section for each recipe, grouping them by ‘genre’, and maybe a header section for ToC and shopping list. Would it be useful to build a Gantt chart so you can time recipes together?
Thanks for the tips, @maria! I’m starting it now and seeing it’s a little difficult to associate a number in the canvas area with a number in a table—for instance, how would I list a value for the approximate time in the main page and the section itself?
I’ll add you to the doc now so you can take a look and see what I mean. Personal project, so not critical! But feel free to add a recipe if you’d like.
I’m cooking up something (forgive the pun!) for you too! I’ve just shared a basic tracker for you - not to worry other Coda Community folks, I’ll post it here too shortly.
For your question, I added a formula suggestion to the doc! You’ll want to pull from the cookie control.
