Hi everyone,
I’m trying to perform an action on a set of different google Calendars. Currently I have to edit the button for every google calendar I’m trying to perform the action on, which is a hassle I’d like to prevent.
Ideally:
- I’d have a button to put out all the connected google calendar packs to a table
- They’d each have a checkbox
3 So I can perform an action on all of them depending on the checkbox.
Something like this:
Two questions:
- Is there a formula to list all the pack connections?
- If I know the pack connection, and it is the input of a cell, can I link to that column to use the connection. It seems to error there for me.
Thanks for the help in advance
