Part of my doc hygiene is to archive rows out of my working doc so it stays snappy and under any Coda row limits. Part of this process is Crossdoc rows out into the backup doc and then delete them in the original. However sometimes other tables will reference the deleted row. In this case I have a row that was called 'Coda Updates/builds' and it was deleted:
The table that was looking it up still shows it as such, with the dotted line. Any row that references it gets the red corner / error indicator:
Is there any way to extract out the text from the deleted reference ala totext()? While it won’t fix everything that could break from the deref, it would allow a lot to still work … and the data is clearly still in the original doc.
