Hello! I was making a coda and I came across this Reference Broken banner.
I am making like a form to make activity reports and made a table were you select a project and an Activity Type and add the hours spent in the task.
I added buttons to add rows to the same project, and another to add to the same type. I grouped these buttons so they don’t repeat for every row.
The problem occurs when I make a second or third row and then I delete it, even though there are still rows in the same group, when I press the button to add a new one I get the mentioned banner.
Here’s the Doc in question
