Relation table formula problem
Hi Coda wizards,
Here is my problem: I have a table of prompts with categories.
Then I have a table of those categories where I need to show a number of prompts in each category.
Where is my mistake in the formula as right now it is showing the total number of prompts everywhere?
Hello @M_G
Your “Prompt Category” column is a relation to the “Prompt Categories” table, so what is inside this column is an object, not a text.
Try to remove the “.Name” property.
[AI Prompts].filter([Prompt Category].Contains(thisRow)).Count()
Best regards,
Arnhold
@Felipe_Arnhold I tried that - everything changed to zero:
I think the issue is that you have:
[AI Prompts].filter([AI Prompts.Prompt Category].Contains(thisRow)).Count()
But you want, exactly as Arnhold wrote,
You should reference CurrentValue.Prompt Category instead of a second reference to the AI Prompt table inside of the AI Prompt filter.
As johan says,
you have to use the currentValue of prompt category
[AI Prompts].filter(CurrentValue.[Prompt Category].Contains(thisRow)).Count()
You guys are awesome. Thank you very much!
