Table 1 has a list of items in the first column.
Table 2 uses that list in a relation column, where I can select options.
When I try to count the occurrences in Table 2’s relation column from Table 1’s list of items, I get the total number of rows in the column or 0. This is the formula I’m using:
I found a work around, but I think there is still a bug with the system. Because when I typed in the solution from scratch as a formula it did not work:
