Hello Coda Community,
I have an issue I’ve been trying to figure out for too long.
I’m trying to do some resource planning using a simple calculation - we were using Excel, but I can’t for the life of me figure it out how to do it in Coda.
Basically here’s what I have so far:
I have a table, in that table I have rows as “projects” in the projects, I have three columns for efforts for each of our three teams.
Those efforts are large, medium, small and micro - and for the sake of this example, let’s say they equal 4,3,2,1 in numerical value respectively.
Each project has an efforts assigned to it for each of our three teams - so on any given project, effort might look like: Team A has effort of (large) 4, Team B - (small) 2 and Team C - (micro) 1
So, looking at any given quarter, we have multiple projects within that quarter:
For example:
Q1 has 6 projects
Each project has as above, 3 effort levels as mentioned above.
What I want to do:
Count the number of large, medium, small and micro projects in any given quarter - sum up the values for each team’s efforts
(e.g.) Each team sees the 6 projects differently when it comes to effort - Team A has 4 “large” projects, 2 “small” projects and Team B has 1 “large”, 5 “medium”
So, in my resource table which is separate from the projects table, I have teams represented for each row, and as columns, I have quarters (1 through 4 for 2021)
I want to see under the Q1 column for Team A a total sum of “effort” adding up all the values from above and giving me a whole number - so the outcome using the example above would be for Team A a total amount of effort for the quarter is 20 (4 large = 16, and 2 small = 4)
Then I will use conditional formatting to tell me if that 20 number is more or less than the max capacity for that team for the quarter.
Hope this makes sense
Thank you!
