Hello all, Really was looking forward in getting back into Coda, coming from Notion. And its very Frustrating to not be able to just create a row, enter data and then click a button or drop down to have your template generate over that info… Notion is very simple cut and dry to to do this. I been at this for almost 4 hours of wasted time trying to understand how to or even get a basic formula to do it. To be honest your formula is not easy to use. Well I tried guest i have to stick with notion.
This is a duplication of another post you made, I will ask for it to be removed.
Do understand hope someone can answer my question then. Since its been two years an no update.
Thanks so much for reaching out @Feedback_Entertainment and for flagging this as a duplicate post @Piet_Strydom . If you are looking for an update about a specific issue, we recommend reaching out directly to our Coda Support team by clicking the ? in the bottom right corner of your Coda screen and submitting a feedback form with this information. In the meantime, I will be closing this thread for further commenting. Have a wonderful day!
