Looking to allow non-Coda users to rsvp for an event (name and email) and it feels like I’m doing something wrong…
Embedding Google Forms gives me an error, using Typeform gives me the below image which takes up way too much space - is there a work around with a table? I don’t want to make the document editable because then everything can get edited. Thanks!
Dear @Kevin_Levine,
It will be helpful if you could publish a dummy copy of your doc, to have better chance to find a solution
Great idea! Here is the link to the published doc:
Dear @Kevin_Levine,
You can edit the size of the embed a little bit by edit the embed as displayed
And reduce the width, the height is according my best knowledge not adjustable
Hey @Kevin_Levine & @Jean_Pierre_Traets
If you use the embed formula instead of the embed widget then you’ll have a little more accurate control of the size (height and width). Note: unfortunately limited width.
Just type “=” on the canvas, and then type “embed”
eg:
