SAP Connection?
Is CODA connected to SAP?
Hi,
Short answer, no.
But what kind of connection are you looking for? Config, master data or transaction data?
But SAP has API’s, and Coda has packs…
Piet
I have been doing SAP implementations for more than 25 years. I see HUGE potential to use Coda to make the process
  • More efficient
  • Self documenting
  • A continuous source of information used continuously after the implementation by both end-users and support personnel.
It would be great to have a discussion with you.
Piet
