I’m moving my business from Airtable to Coda and so far, I like it a lot.
One thing I couldn’t find was the possibility of adding autonumbers or sequential numbers. I searched this forum and found some workaround using formula but it’s not the same thing. I use it for invoice numbers and older numbers aren’t supposed to change if I add a row or change the order of the record
Will it ever be implemented?
hey @Breno_Nunes can you be a bit more explicit in what you are trying to do? I’m guessing but here is a possible solution. You have a table [Invoices]:
[Invoice] [Amount]
5 $100
6 $100
7 $100
What you can do is create a stand-alone formula, say ‘Max Invoice’ on the canvas that =[Invoices].[Invoice].max() which will return 7.
Then you could have another formula, say ‘Next Invoice’ which =[Max Invoice] + 1.
Then in your [Invoices] table, format the invoices column so that Value for New Rows' formula = Next Invoice.
You can of course merge these formulas into one for simplicity. Good luck!
Hi @Breno_Nunes,
firstly, welcome to this community!
As @Johg_Ananda suggests, this might be a smart implementation.
However, just note that RowId(thisRow) is the exact homologous as Autonumber column in Airtable.
You can even automatically set it up by adding a new Row ID column from properties:
Hope it helps.
Hi @Johg_Ananda and @Federico_Stefanato
Thank you very much for the speedy reply.
I am going to try it.
Breno
