I’m trying to create a view of a table that has a sub set of fields that I want visible.
It works great until a users presses on a card, then it opens and everything is visible
What I mean is that I got the cards to look right (have only the info that I wanted to show), but they are clickable, and there the user can see all the info which I don’t want them to see.
Any ideas how to solve this?
What are they different options for me to define who can see what?
When you are inside the popped open view of a row (also called the detail or modal layout), you have an option to EDIT that layout as seen in the screenshot below
Once editing layout, you can hide or show as many columns as you would like
