Simple Automation Formula
Hi all, I’m working on a simple automation and am stuck. The goal is to trigger a notification when the status of a column changes to “Published”. I feel like I’m really close on step 2 / the “If” statement, but can’t get it to work. Thanks in advance!
You step 2 if statement looks good! Now you just need to do step 3, the action. Use a notify action and you should be good to go!
