Hi,
I’m new to Coda but loving it so far.
I run a construction company and use Coda and Airtable to organise my work flow.
I have a table with info about window quotes. size, type, room location etc.
Its in a table which I use to display the info to clients.
I use a concatenate formula to gather all the data into one place and present it as a list. Using the new column functionality I’ll add an image of the proposed window alongside the info. an example below:
Concatenate(“Window: 3”,Character(10),
"Location: ",[Window Schedule].Location.Nth(3),Character(10),
"Floor: ",[Window Schedule].Floor.Nth(3),Character(10),
"Style: ",[Window Schedule].Style.Nth(3),Character(10),
"Opening: ",[Window Schedule].Opening.Nth(3),Character(10),
"Manufacture width: ",[Window Schedule].[Manu width].Nth(3),Character(10),
"Manufacture height: ",[Window Schedule].[Manu Height].Nth(3),Character(10),
"Safety glass: ",[Window Schedule].[Safety glass].Nth(3),Character(10),
"Obscure glass: ",[Window Schedule].[Obscure glass].Nth(3),Character(10),
"Fire escape: ",[Window Schedule].[Fire escape].Nth(3),Character(10),
"Trickle vent: ",[Window Schedule].[Trickle vent].Nth(3),Character(10),
"Notes: ",[Window Schedule].Notes.Nth(3))
Can I add something to the start of the formula so that I don’t have to manually change each formula to the correct window number?
In this instance Window 3, which is row three of the table
Thanks in advance
