Small column name hover fix
Hello Coda team,
When the columns are too thin the dropdown stays over the name and doesn’t display the full name popup on hover. I wonder if you could do it so that it continues to display the full name popup even when on dropdown hover.
In the example below the third column shows what I mean. (I don’t want to widen the columns since the view of the data is perfect that way)
