Is there a way or a trick to keep layouts organized? I’ve started to use them quite extensively and having a way or organized them or at least organize them alphabetically (when necessary) would be helpful.
Thank you
EDIT: (I should have put a pic since the beginning to make the question clearer.
It’s messy and some of them should have been deleted time a go, but it’s just to show that a sorting feature would be useful)
Usually that will depend on your users needs. I organise them based on my frequently used tools:
This also means that my views will change over time as my priorities change:
For example, a manpower company that i manage, my views were:
open appointments (for workers to take up)
scheduled appointments (for workers to refer to)
3 months later as i start to have more monthly contracts, i would add another view:
recurring appointments (for workers to followup with clients)
Thanks for the reply and the example, what I was hoping for tough was for a way to sort-rearrange the layouts in order to organized them better. It seems that there is not native way to do that in Coda, and I was hoping for a workaround
