When doing a numbered list in the canvas, if you press double enter to add content in between the numbered list, the following number changes back to 1. Is there a way to continue with the automatic consecutive number?
Luis, rather than having a paragraph break, you can use SHIFT+ENTER to add a linebreak. If the content is indented, this will create a hanging indent allowing the bullets / numbers to continue correctly.
Also as long as all the lines in between are tabbed, the numbering will stay in the same list. The logic looks for a line where the tab stop is 0 as an indicator to start a new list.
