Hi Coda Team,
After the latest update, starred documents are under organisation/my shortcuts, which moves them away from the left navigation bar and makes access slower.
It would be great if they could be pinned to the left nav bar, the whole point of starring documents is that it gives you quick access to them.
Thanks
