Hi. I have a table of long texts in English, and I would like to be able to use the OpenAI pack to summarize in a different language.
Because I want the summary in a different language, I cannot use the normal ‘Summarize’ formula. Any suggestions?
Yes!
First summarize using the OpenAI pack and then translate using the free google translate pack.
I would recommend using the ai pack with a button to summarize as shown below
Awesome! Thank you very much. But I did come to realize there were limits to how accurately OpenAI can summarize complex texts. ![]()
Did you make sure to use the best model text-davinci-003? ![]()
Oops, I had the setting on the default ‘text-ada-001’. Thank you for pointing this out. I will give it a try. Hopefully I now won’t have to manually summarize over a thousand rows of long texts ![]()
