Coda AI is a powerful tool for extracting key information from your team’s content. Often, makers use Coda AI to summarize briefs, pull out action items from meeting notes, and analyze customer feedback, so we’ve made it easier to accomplish these goals.
New AI column prompt builder to create AI content in every row.
If your table data contains a lot of text, AI column can pull out the important details from each row. For example, your table with meeting notes might have a row for each topic, and feedback from the discussion. An AI column could then list action items, giving teammates clarity, and moving projects forward.
If you add a new AI column to your table, you can choose from one of four preset options: summarize, find action items, find key insights, or a custom prompt. Next, from the dropdown, select which column contains the relevant context, and then add any further instructions. If you’d like Coda AI to reference multiple columns (or to reference other tables through the formula builder), use the custom prompt option.
One-click summaries & new AI block prompt builder to get an overview, instantly.
If you’re writing a brief, a summary can give your teammates context, and ensure they remember the key points. Now, you can summarize any page with one click. Hover over the area above the page title, select summarize, and an AI block will be added.
AI blocks also have a new structured prompt builder, where you can choose from the preset options (summarize, find action items, find key insights, or a custom prompt) and select which page or table contains the relevant context. Add more instructions, and then name your AI block so you can reference it in formulas throughout your doc. If you’d like Coda AI to reference multiple tables/pages, use the custom prompt option.
With these features, you can now review customer feedback, revisit meeting notes, navigate briefs, and draw other insights from your content more easily.
