Hi, Could anyone suggest how to sync Jira to Coda
Dear @oskotskayasvetlana,
I don’t use Jira, but from experience with other packs I learned that sometimes it’s helpful to re-connect the pack or to give it a try in a new doc. Just to see if the problem persists.
Otherwise you could contact support@coda.io
Hello!I tried that and got weird results. Everything works in the document, but in the backup copy of the document where it doesn’t work, it doesn’t work either ![]()
