Text To Speech (TTS) v2
Because Coda doesn’t work on MS Edge on Android (mobile), I can’t use it’s TTS function. And Android’s accessibility tools are horrible to use.
What plans does Coda have to integrate TTS into its platform? And what tools exist currently that I could use to listen to docs and canvas fields in Coda?
The suggestions offered in my previous inquiry were only for desktop not mobile. Also the suggestion to download the coda app was unhelpful, as the coda app is unusable — it is littered with bugs.
