Hi
I’m trying to create a formula that if the following number matches then do something.
Now I can use pretty much everything and it works but not this number; 2810-103. It turns out that I can use anything as long as not a number like 1234-123 (4 then a 3).
The column has to be formatted as a text column as other values maybe 2301PA, 5421-123, 3011WS-123.
It seems if i click on the cell and copy the contents ‘2810-103’ and paste it into my formula, it pastes: ‘EpochToDate(26531625600)’
If I copy ‘2301PA’ it pastes ‘2301PA’
Now this has to be the issue but I can’t get around it.
Any ideas?
