Hey guys. I want to clean the cells I have selected in the table, but I don’t see how I can do it. I even asked ChatGPT, which told me that after I selected a set of cells there must be some button that looks like three dots but I don’t see anything like this. Now if I selected a cet of cells and use delete button it deleted the whole row I created.
I already searched in community forum, Googled and searched on Youtube. It seems that I must be really stupid and don’t see something that is so obvious that nobody even wrote about it.
Eventually I started typing all buttons at the keyboard while keeping the needed area selected and found out that Backspace cleans the values.
It’s not what you asked but just in case someone makes a research about this topic, if you often have to clean a certain set of cells, you can do it using a Button column type. Using “Modifiy rows” > ThisRow you can clean the columns you want in a particular row.
Using a button outside the table you can choose to clean entire columns. And you can even choose to filter what rows need to be cleaned. ![]()
This is what I searched for though. Thank you Sonia!
