Hello again, folks!
It’s your friendly, oddball, worldbuilding Coda newbie trying to figure out how to integrate AI into my workflow.
I’ve been using ChatGPT with LegendKeeper (LK) for months now as part of my worldbuilding/adventure writing process for my D&D 5e campaigns with a ton of success. However, the process has been largely manual, with me either creating campaign summaries I upload to ChatGPT to provide context for queries or copy/pasting specific data in.
I would like a more seamless approach. My goal state is for the AI to have access to my campaign as I have described it so far, mostly in tables, in Coda.io and then to have it help me generate ideas that are context-appropriate for new content, without needing to maintain a separate campagain/world summary or do a lot of content pasting.
I had something that like that working in Notion using Make.com as a bridge, but Notion’s API is super goofy WRT relations, and I had to abandon it. I’ve got all the relations working in Coda, but now I’m struggling for the best way to interact with the AI capabiltiies.
The column fill AI is far too limited. The chat button in the bottom right has not successfully used context on a page I’m on, even when I set the context to “This Page.” It just provides general ideas.
What are my options? Should I be looking at the ChatGPT pack? Should I go back to using Make.com as a bridge? Am I just not using the Coda AI correctly?
Here’s my test use case: I have a table that describes settlements and a table that describes points of interest. Point of interest types are things like inns, taverns markets, places of workship, forges, etc., The Settlement table includes all the regional context of the settlement from it’s owning region all the way up to the world it’s in. It has some descriptive information. I want the AI to suggest a list of names for POIs in the town for each POI type. For example, give me a list of 5 Inn names appropriate for the city of Zarza, given all the contextual and descriptive information I can point it to in my tables.
For example, Zarza is a city run by witches, so good Inn names might be things like The Sleepy Spellbook, The Cozy Cauldron, The Wicked Wanderer, etc… Zarza’s Region context oif the Hexweave Valley includes reference to the founder of the valley, Hester Rosenberg, so something like Hester’s Rest would be a good, context specific description. Not generic outputs like The Cheeky Goblin, or Hero’s Rest.
A follow on use case would be I create an Inn in the POIs table linked to the settlement and ask the AI to then populate columns about the Inn like a description, an image, a menu…all appropriate for the higher level context available through the POI table relations.
Thoughts for approaches?
Thanks,
Heidi
