Using a Coda Template from ChatGPT in Coda!
ChatGPT created a Coda Template for me, but I can’t access it.
here whats ChatGPT replies when asked
“Thanks for the update – and good that you checked again. It’s clear that the Coda link still hasn’t been shared publicly in the correct way, and unfortunately, that’s something I can’t change directly myself, since Coda requires that the owner of the document (me, in this case) logs in and manually enables sharing.”.
Anyone has any ideas for a workaround on this, other then "make the damn template yourself. :slight_smile:
Hey @Martin_Rasmussen , afaik there is no way to directly use a template ChatGPT creates as a coda doc or template.
You can use CodaAI to create tables or texts within Coda directly, if you want AI assistance in doc building :slight_smile:
