Using Coda as Quality Management System
Hi,
Hope you are all well.
I am considering using Coda as a Quality Management System to be able to comply with ISO type standards. I would really appreciate it if anyone has any suggestions on how to replicate the following elements that would normally be part of such a system:
  1. Revision and Approval History of a document
I appreciate that Coda tracks every change but in a QMS, one has to adopt a more formal process. Google Docs allows naming a version but this is not the same as the above because the above type of process needs to record approval of documents as well.
  1. Recording sign off status
We have to record whether our employees have read an SOP. This is usually done by having a table at the bottom of a word document:
Note that sign off needs to occur for every revision of a document.
EDIT: Also, not every user needs to read every document so we would need to have some sort of personalised path.
  1. Tracking sign off status across multiple documents
It would be a bit unwieldy to monitor the sign off status of documents individually. Ideally we would need to track the sign off across the whole QMS depending on whether an individual has been assigned that procedure or not.
Thanks for your thoughts on this tricky problem.
Shaheed
Dear @Shaheed_Fazal,
Depending if you want to start for scratch or have already an archive of docs that need to be managed this post from @Al_Chen_Coda, might be of your interest.
As you already mentioned:
It’s an interesting challenge, but to be able to start you will need to create “requirements doc” in the form of a mind map, to see all resources, procedures and relations that need to be followed (flow).
Then you could make an initial version and start to play/debug it
[quote=“Shaheed_Fazal, post:1, topic:17927”]
[/quote] :thinking:
With a button in Coda can be created a “read confirmation” log file
Hi @Shaheed_Fazal, as @Jean_Pierre_Traets said, you could utilize a button that the employee could click to indicate if they have read a new version of the SOP. To automate this workflow, you could make the button activated (available for the employee to click) if the SOP has been edited recently (and the date of the most recent edit matches the date for some arbitrary version number). You could experiment with the Modified and ModifiedBy functions in a table to start tracking when employees have signed off on different versions of the SOP.
Hi @Shaheed_Fazal,
Depending on how strict you need to be for this, you could go as far as embedding a PDF for each item they employee needs to read and with the button action that marks the employee as having read, also have it send an email to a company account and the employee that they have read that PDF and include a link to it in the Email. This would give you a second timestamped record that can’t be edited after the fact.
