When I click a button I have defined which amongst other things, uses the Today() function to populate a cell in a table to today’s date, sometimes it works, other times I get yesterday’s date.
I have done a search and seen similar reports from 2018 and 2019 with a suggestion to add an offset of X hours with reference to my location. The thing is I am finding it is intermittent so I’m not sure it is an offset issue. If it was, surely I would consistently get yesterday’s date?
I suggest to contact support@coda.io to have a look on this subject.
It would be great if you could share the outcome, in case somebody else faces such error in the future, thank you.
