In my scenario, there are 4 tables in question which serve a single business process. I’ll try simplifying things by listing the table names ie “Table1”, followed by a list of columns.
Let’s assume the 1st column in each table is the Display column.
Table1 - ID, Email
Table2 - ID, Email
Table3 - Email, Name, etc.
Table4 - Email, Name, etc.
The way the continuity of the business process looks like is:
- Execute a child process that involves both Table1 & Table2. The ID column is specifically required for this child process to succeed.
- Execute a separate child process that involves Table3 & Table4.
Once the child process with Table1 & Table2 is finished, there’s no reasonable way to capture the ID value so that it can be used for the separate child process that involves Table3 & Table4.
Meanwhile, the “Email” column is a common column between all of them.
Is there a way to have columns or links between Table3 or Table4 to refer to Table1 or Table2 by using the “Email” column as a second de facto Display column? So I can pull data from Table1 into Table3 for example? And vice versa?
