Hi there, I’m a bit stuck on the use of CurrentValue.
My current project involves building a taskboard where tasks can have subtasks. Those subtaks can have subtasks as well, etc. These are all linked relations on the same taskboard.
I want to prevent the user from selecting a task as subtask for if it’s already a subtask of a subtask of the current task.
Case sample:
Parent task 0
Child task 1
Child task 2
Parent task 1
Child task 3
Child task 4
When clicking the dropdown for subtasks of Parent task 0, I do not want to show Child task 2, 3 and 4. I do want to be able to select Parent task 1, making it a subtask of Parent task 0.
I tried filtering it out with CurrentValue, but then it just references itself in the last CV reference:
CurrentValue!=thisRow AND [Bovenliggend issue]!=thisRow AND Not([Sub issues].FormulaMap(CurrentValue.[Sub issues].Contains(CurrentValue)))
Who can help me solve this riddle of logic?
Warm regards,
Freerk
ps. I’m stuck for the first time in a long while, so yay to all the amazing guides already out there!
I looked into it, but unfortunately couldn’t find a condition to filter the selection consistently.
I would suggest changing something in the structure of the document so that you have a clean hierarchy.
If you have a clean hierarchy in your table, filtering is much easier.
Please take a look at this topic, which helped me a lot in building a task hierarchy:
