I am trying to get a datetime value update for a calculation row, e.g. no of items.
It should update every time it calculates this value again.
But I get a blank value
thisRow.select.Modified()
Question: what then triggers the Modified on?
Best
Thomas
Dear @thomas_raizedai,
Welcome to the community!
As far as I understand your updates are coming from formulas and updates from formulas will not reflect in “Modified()”
Maybe there is “a way around”, for example when a button is pushed it’s possible to monitor when this happened, therefore it’s recommended to share a dummy doc and there is a good chance some community member might suggest you some solution(s)
