depends on which columns are visible when this view is in Table mode!
Thatās right, not the columns thatās visible right now, but only when you switch to Table mode, make the required ones visible, and then switch back to Detail
Learned this from @Krunal_Sheth through Coda support.
@mallika I took me a while to discover that when needing just 1 section (but not all the other sections) from a community template ⦠since there is no way to Shift / ctrl + click and then delete, the most efficient way to delete multiple sections is to add the unwanted sections to a folder and then delete the folder containing all the unwanted sections
When you reference the master table in the formula, it always works on a full set, whether or not a filter is applied.
When you pull the same data from a view, it will only use the filtered subset.
Sorting setting doesnāt matter in either case, you need to explicitly .Sort() in your formulas:
IDK, I prefer to rely on master tables only ā more predictable that way. I like to explicitly write in my formulas what exactly I need from the full data set and how.
One exception is that if itās a formula that is only used once and nearby the view in vicinity ā e.g. a header saying Hello User(), today you have [Your tasks view].Count() tasks. I.e., when itās apparent that this formula describes the view beneath it.
UPD: When I meant ārely on master tables onlyā, I meant in the context of working with the full data set directly and not segmented via lookups. If e.g. I have a table of users and a table of tasks, Iāll first pull in each usersā tasks into a lookup column of a Users table, then refer by @Some user.Tasks. I wonāt write it like Tasks.Filter(User = @Some user) in that case. TL;DR: If I can connect the data, Iāll do that first.
@Paul_Danyliuk, I had the same feeling: somehow itās like not really be sure of the underlying data.
I discovered it really helps a lot (i.e. better UI performances) when many rows - and many columns - are involved.
Often itās just a matter of proper View naming.
Think about the overall historical Exchange Rates (master table) and Current Rates (the View with current valid ones) anytime you need to have exchange computations. Looking up a single field with few rows dramatically increase computation times.
Anyway: didnāt want to drag the attention away from this post
@Federico_Stefanato Never tested it actually, but I think that if we were after micro-optimizations, we wouldnāt be using Coda but write it in C++/Java/etc
I mean, with tools like Coda, I believe good data design and sensible conventions are more important than performance.
But yeah, there are always exceptions, thatās why I always say use your best judgement.
However, in your case Iād say you could approach this differently and have both better design and performance. Iād keep the historical Exchange Rates table, but instead of the view Iād make a Currencies master table that looks up the most recent exchange rate for each currency into a lookup column. Then reference the Currencies table when I need to get the most recent rate ā e.g. with a direct row lookup like @GBP.[Current rate]
@Paul_Danyliuk - this is fixed now. now you would see all allowable columns in the dropdown. - the fix would be deployed in a day or two. Thanks for reporting the issue.
This will probably sound silly, but I just realized that when I add a column to a View, it gets added to the base table. I thought views become their own table that can extend the base table. I mainly didnāt notice this because I tend to not modify a viewās table structure, only visuals.
I often add columns for buttons only to the View, thinking that it is stored off separately in the View only.
Do you think this was always the behavior, or do you think after the WithName introduction the behavior might have changed (or around then)? Remember, it used to be that you could only add the RunActions at the beginning of your formula, you couldnāt include it inside of your loop iirc
If you could only put RunActions at the beginning of your formula then it would always be the same behavior.
I have a feeling itās a recent change introduced with this patch:
because this one hints at how Coda changes the behavior of actions to be non-blocking in certain scenarios.
Or it could be a change introduced along WithName(), although I donāt remember any regressions in this regard at the moment.
Fact: I donāt remember having any problems with omitting RunActions() in a FormulaMap before. I only noticed it now. I was doing quite a lot of client work and I used to omit RunActions() quite often. So I assume that if this behavior existed before February, I would have caught it already. I had a pause in consulting since February, and I only caught it now. I also caught a few bugs around using CurrentValue and WithName in FormulaMap/RunActions.
Thatās why Iām concerned in the first place. What if this is a recent change indeed and many of my old clientsā docs are now broken?
Other than this, thereās evidence of RunActions() forcing sequential behavior back in 2019:
Thereās no evidence that lack of RunActions() used to run non-sequentially though.
Never heard of this; I never doubted that I could use RunActions anywhere, it never gave me any errors. FWIW I joined Coda in Mar 2019; maybe it was different before that.
Interesting fact: a button would always implicitly wrap your whole action in RunActions() even if itās just one action that youāre running. You can inspect that by āmerge()-ingā the button and seeing its pending evaluation formula.
@ references to other rows, especially useful in filters like thisRow = @otherRow. This is a pattern I use in every doc I build now, but for the longest time I never knew about it (and I likely never would have discovered it)
That publishing a doc in Edit mode is vastly different from sharing a doc in Edit mode. I think this would have been clearer if it were to be called āProduct modeā or āUser modeā to make it clear that the user could push buttons but not edit text (I know itās in the tooltip, but my familiarity with the word āEditā made me think that there was nothing new to learn)
Set as Display Column, I initially didnāt know that this also changed the value that the column resolves to. So changing the display column on my early docs would cause bugs this seems to have been fixed. Now you cannot implicitly coerce a row to its display value. Nice!
I tried to cross doc a table and it drove me nuts that my filter function for an automation button did not work as I expected. I cross doced a tasks table, and the tasks table had a lookup to a project table.
When adding a filter function for the āprojectā column I got the message that the referenced data could not be found, but I mistook that for being a limitation in the cross doc table instead of that the actual data could not be found. The reason for this was that I saw the data in the table just fine. Except for it being marked (with dotted lines perhaps)?
I think it would be a good idea to add a slight better error handling or inform the users better in this case. Perhaps you could add something like ā(references in cross docāed tables need to also be cross docāed)ā to the error message of "Data referenced could not be found). Or adding a red dotted line or something to the column data and a popup on mouseover of ādata can not be used in functions unless referenced tables is syncedā or similar. Perhaps you could add a ādoās and donātsā to the āCross Docā page that always pops up when adding a cross doc.
