Where is the dropdown menu in a Details Display with "bottom" Navigation?
Hi, there!
I was hoping someone from the community could help me with this.
When the Detail Display is set to “Navigation: left”, I get the dropdown menu to select from the existing rows.
When set to “Navigation: bottom”, the dropdown menu doesn’t show (or maybe I just couldn’t find it). Only the “Add New” button is present.
I am not sure if this is a bug, if it’s just how it is, or if there is any another practical way of adding a relationship to the Display view.
Any help is much appreciated!
I have no idea what has changed.
Before, when I would press the “+” button at the bottom navigation, it would immediately create a new row in my relationship table, which was not the desired behavior.
For some reason, now when I press the “+” button the dropdown appears, and I can select from the list of existing relationships, as I wanted.
The issue has been solved for now.
