I need to select specific cells in a column from multiple NON-adjacent rows.
In every Software you would normally use ctrl+lmb, but this in Coda only works for the whole rows: try ctrl+lmb on single cells and it would work as shift+lmb select all the cells in-between.
Is this an intended behavior?
How would you paste a value to multiple cells of non-adjacent rows?
I need to select only cells of “Chapter” column from row 1 and 5
However it’s possible to select non-adjacent whole rows
