I have a table with around 1,000 rows. On the page, situated right above the table are some filter controls. My two questions are:
Is there some way to know, jut by looking, if one of the controls has been used to filter the table? As it is, I need to open the the control’s pull-down and see if there are checkmarks next to all, or only some, of the choices. It would be great if I could tell, just by looking, whether a filter control is being used. For example, if I could make a little red dot appear next to any filter that has been used, or something like that.
I often use the little search box at the top right of the table. If I have scrolled down a bunch, then that search box isn’t available unless I scroll all the way back to the top. There must be a shortcut to bring up a search box from wherever you are, no?
Thanks in advance.
