Hi Everyone,
I am trying to disable a button if the current user is not listed as an “approver” on a row. This function works well if only one user is selected in the select box, but doesn’t work if I select more than one option on the select box.
Here is the formula I am using (its the last function I need the help with):
thisRow.HiddenDateSubmission != “” OR thisRow.[Quote Received] = “False” OR
User() != thisRow.Approver
The button is active here because I am selected as the approver (and only me)
This one myself and one other is selected as approvers, and the button isn’t active, but should be.
Any help would be most appreciated!
