Activate(thisRow) as full screen not modal view
I have a set of documents (which reside in a canvas column) wherein the row has a status of either Approved or one of a handful of states other than Approved. The general population are only able to see a read-only view of the Approved documents and I’ve given elevated rights to people who need to be able to view all of the unapproved documents.
TLDR
I am trying to replicate the functionality of Activate(thisRow) wherein it opens as view=full versus view=modal.
I thought I had solved it with the following, but that lends a view of the main table, not a view of the linked table.
OpenWindow(
  Format("{1}{2}",
    thisRow.Url(),
    "&view=full").ToText()
I tested hardcoding the document number, which works as expected, but needs to be made dynamic to be useful.
OpenWindow(Format(
  "{1}#_tuKCv/{2}&view=full",
  "https://coda.io/d/_dhAHs6sWgd5",
  thisRow.Url().Split("/").Last()
I assume there is a super obvious solution I am over looking here…
Hi @Nate_Eikelberg :blush: !
I’m not entirely sure but have you tried OpenRow() ?
Something like:
OpenRow(thisRow,viewMode: "fullscreen")
You can also specify the view where the row needs to be opened :blush:
OpenRow(thisRow,[Specific view of my table],"fullscreen")
Just in case, here’s a very quick sample doc to illustrate (even though, maybe I misunderstood your question :innocent: )
The first button (the blue one) you’ll find in the table Main opens thisRow in fullscreen, in the view [View of Main] using this action formula
OpenRow(thisRow,[View of Main],"fullscreen")
The second button (the purple one) opens thisRow in a modal, in the view [View of Main 2] using this action formula :
OpenRow(thisRow,[View 2 of Main],"modal")
And the third one, somewhat gets you back to the main table :blush:
A small note but it seems like Url() is not really used anymore, I think :thinking: … But there’s ObjectLink() :blush:
Thanks, that’s exactly what I was looking for – but had no idea existed!
Yes thanks for bring that up – I’ve noticed a few functions I’ve used in the past now say deprecated, but wasn’t sure what more-recently adopted function should replace it.
No problem @Nate_Eikelberg :grin: !
I’m very glad to know OpenRow() was indeed the missing piece here :raised_hands:
