Hi all,
As suggested by the subject, I cannot adjust the column width of a table under group view(both top and left).
As you can see, 2023 and 2024 gets a bit cluttered.
Is it designed like so or am I missing something? Thanks!
Hi all,
Hi @Chen_Zhong , thanks for reaching out! You should be able to adjust the width of your columns by hovering over the space to the right of the top of the column and dragging it. If this isn’t working properly for you, we are happy to take a look directly at your doc to see if we might be able to find the source of the issue. If that’s the case, would you mind providing a link to your doc?
Yeah I think once a grouped view is active on the top side, it actually locks the column width. When I hover over the edge of the column nothing indicates the ability to change width tho…
Hmmm that’s strange. I just attempted this with columns in a grouped view in my own test document and was able to adjust column width. So that we can see what might be keeping you from doing this in your own doc, would you mind sharing the link with us here?
Did you try specifically grouping on the top? I have already shared the doc with support, here’s a link:
Hey Chen, thanks for bringing this to our attention! It looks like the option is a little hidden. I’m attaching a GIF to show where you need to hover to adjust the column width. I’ll also pass this feedback on to our product team for review. Let us know if you have any other questions!
Yeah I can see that now. However it requires a lot of careful maneuvers…would be nice if we get a simple table-wide parameter setting to adjust width based on parameters (like Excel)
